Get a Planned Output Object
Use this API to retrieve a Planned Output object for an LSH object.
Name
CDR_PUB_DF_PLANNED_OUTPUT.GetPlannedOutputObject
Signature
FUNCTION GETPLANNEDOUTPUTOBJECT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  PI_NCOMPANYID  IN    CDR_NAMINGS.COMPANY_ID%TYPE,
  PI_NOBJID  IN    CDR_NAMINGS.OBJ_ID%TYPE,
  PI_NOBJVER  IN    CDR_NAMING_VERSIONS.OBJ_VER%TYPE,
  PO_PLANNEDOUTPUT  OUT    CDR_PLANNEDOUTPUT_OBJ_TYPE
) RETURN BOOLEAN;
Return
Type BOOLEAN
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NCOMPANYID (Mandatory) Enter your company ID. To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.CURRENT_COMPANY_ID.
  • PI_NOBJID (Mandatory) Enter the OBJ_ID value of the object for which you want to retrieve the Planned Output object.
  • PI_NOBJVER (Mandatory) Enter the OBJ_VER value of the object for which you want to retrieve the Planned Output's object.
  • PO_PLANNEDOUTPUT This is the output parameter of the API returning the Planned Output Object.
