Modify a Planned Output
Use this API to modify an existing Planned Output.
Name
CDR_PUB_DF_PLANNED_OUTPUT.ModifyPlannedOutput
Signature
PROCEDURE MODIFYPLANNEDOUTPUT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_POUTOBJTYPE  IN OUT    CDR_PLANNEDOUTPUT_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Planned Output.
  • PI_POUTOBJTYPE (Mandatory) This is a parameter of table CDR_PLANNEDOUTPUT_OBJ_TYPE that contains attributes specific to Planned Outputs. Enter values for the Planned Output and enter new values for the attributes you want to modify. You can change the name or description of a Planned Output.
    Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION.UPDATE VAL STATUS and CDR_PUB_DF_NAMING.UPDATEVERSIONLABEL.
