Get the Usage Intent RC of a Work Area
Use this API to retrieve the current value of the Usage Intent attribute for a particular Work Area.
Name
CDR_PUB_DF_WORKAREA.GetUsageIntentRC
Signature
PROCEDURE GETUSAGEINTENTRC( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PO_USAGEINTENT OUT CDR_WORKAREAS.USAGE_INTENT_RC%TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_COMPANY_ID (Mandatory) Enter company ID
- PI_OBJ_ID (Mandatory) Enter the object ID of the Work Area.
- PI_OBJ_VER (Mandatory) Enter the object version (OBJ_VER) of the Work Area.
- PO_USAGEINTENT This output parameter returns the current value of the Work Area's Usage Intent attribute.
Parent topic: Define and Modify Work Areas
