Update a Work Area's Usage Intent
Use this API to modify the value of the Usage Intent attribute of a Work Area.
Name
CDR_PUB_DF_WORKAREA.UpdateUsageIntent
Signature
PROCEDURE UPDATEUSAGEINTENT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PIO_WORKAREAOBJTYPE  IN OUT    CDR_WORKAREA_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area whose Usage Intent attribute you want to modify.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER.
  • PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. For USAGE_INTENT_RC, enter the new value for the Usage Intent attribute.
    The allowed values are: $SYSVALDNSTEPS$DEVELOPMENT, $SYSVALDNSTEPS$PRODUCTION, $SYSVALDNSTEPS$QUALITYCONTROL.
