Modify a Validation Check Batch
Use this API to modify a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.UpdateValidationCheckBatch
Signature
PROCEDURE UPDATEVALIDATIONCHECKBATCH
( P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_BATCHMAPCOMPID IN OUT NOCOPY CDR_NAMINGS.COMPANY_ID%TYPE,  PI_BATCHMAPOBJID IN OUT NOCOPY CDR_NAMINGS.OBJ_ID%TYPE,  PI_BATCHMAPOBJVER IN OUT NOCOPY CDR_NAMING_VERSIONS.OBJ_VER%TYPE,  PI_BATCHNAME IN OUT NOCOPY CDR_NAMINGS.NAME%TYPE,  PI_BATCHDESCRIPTION IN CDR_NAMING_VERSIONS.DESCRIPTION%TYPE,  PI_ISORDEREDFOREXECUTION IN VARCHAR2,  PI_CANBETRIGGERED  IN VARCHAR DEFAULT '$YESNO$NO'
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_BATCHMAPCOMPID (Mandatory). Enter COMPANY_ID of Validation Checks Batch Map.
  • PI_BATCHMAPOBJID (Mandatory). Enter OBJ_ID of Validation Checks Batch Map.
  • PI_BATCHMAPOBJVER (Mandatory). Enter OBJ_VER of Validation Checks Batch Map.
  • PI_BATCHNAME (Mandatory). Enter Batch Name for new Validation Checks Batch
  • PI_BATCHDESCRIPTION (Optional). Enter Batch Description for new Validation Checks Batch.
  • PI_ISORDEREDFOREXECUTION (Optional). Enter $YESNO$YES, if Validation Checks under new Batch must be executed in particular order. Otherwise enter $YESNO$NO. If entered as NULL, systems defaults it to $YESNO$NO.
  • PI_CANBETRIGGERED (Optional). Enter $YESNO$YES to allow the successful completion of a transformation writing to the clinical data model that this batch runs against to trigger the execution of this batch. Otherwise enter $YESNO$NO. If entered as NULL, systems defaults it to $YESNO$NO.
