Promote a Clinical Data Model to Quality Control or Production
Use this API to promote a study clinical data model to either the Quality Control or Production validation status.
Name
DME_PUB_DF_DATA_MODEL.UpdateValStatus
Signature
PROCEDURE updateValStatus(
p_api_version 		IN NUMBER
p_init_msg_list 	IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit 		IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level	IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
pio_naming      in out nocopy cdr_naming_version_obj_type
x_return_status  	OUT NOCOPY VARCHAR2
x_msg_count      	out nocopy number
x_msg_data       	OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • P_VALIDATION_LEVEL
  • PIO_NAMING (Mandatory): This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model that you are promoting.
    PIO_NAMING.VALIDATION_STATUS_RC (Mandatory): Enter the validation status to which you are promoting the clinical data model:
    • '$SYSVALDNSTEPS$DEVELOPMENT'
    • '$SYSVALDNSTEPS$QUALITYCONTROL'
    • '$SYSVALDNSTEPS$PRODUCTION'
