Install a Study Clinical Data Model
Use this API to install a study clinical data model.
Name
DME_PUB_DF_DATA_MODEL.DeployStudyDataModel
Signature
procedure DeployStudyDataModel(
p_api_version IN NUMBER
p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level	IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
x_return_status OUT NOCOPY VARCHAR2
x_msg_count OUT NOCOPY NUMBER
x_msg_data OUT NOCOPY VARCHAR2
pi_StudyModObj IN OUT NOCOPY cdr_naming_version_obj_type
pi_Context IN VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_STUDYMODOBJ (Mandatory): This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model that you are installing.
  • PI_CONTEXT (Mandatory): Enter the lifecycle area in which you are installing the clinical data model:
    • '$LIFECYCLE$DEV'
    • '$LIFECYCLE$PROD'
    • '$LIFECYCLE$QC'
