Undo a Clinical Data Model Checkout
Use this API to undo the checkout of a study or library clinical data model.
Name
DME_PUB_DF_DATA_MODEL.UncheckoutModel
Signature
PROCEDURE UncheckoutModel(
p_api_version 		IN NUMBER
p_init_msg_list 	IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit 		IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level 	IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
pio_naming		 IN OUT NOCOPY cdr_naming_version_obj_type
x_return_status 	OUT NOCOPY VARCHAR2
x_msg_count		 OUT NOCOPY NUMBER
x_msg_data 		OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model for which you are undoing the checkout.
