Remove Validation Check(s)
Use this API to remove validation check(s).
Name
DME_PUB_VALIDATION_CHECK.RemoveValidationChecks
Signature
PROCEDURE REMOVEVALIDATIONCHECKS
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PIO_VC_COLL IN OUT NOCOPY CDR_NAMING_LIST_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_VC_COLL (Mandatory). This is a parameter of collection type CDR_NAMING_LIST_COLL that contains CDR Naming Version attributes.
    The attributes required for this API are:
    • COMPANY_ID
    • OBJ_ID
    • OBJ_VER
