Compare DMW and InForm metadata on demand
You can compare the metadata—table and column structure—in any DMW InForm model lifecycle stage to any InForm lifecycle database for the same study.
  1. After you select a study, click the Study Configuration icon Shows gear with pencil iconfrom the navigation bar. Then click the Clinical Data Model tab.
  2. Select the InForm clinical data model.
  3. In the InForm Configuration tab, click the Icon is a box with lines.Compare Metadata icon.
  4. In the Metadata Comparison window, select the metadata to compare:
    • For the DMW InForm data model: Development, Quality Control, or Production.
    • For InForm: Development, UAT, or Production.
  5. Click Compare. The report appears on screen.
    To save the report, click the Export All to Excel icon.
    If the system finds no differences, a message appears.
To make the changes in DMW, click the Icon is a folder and an Up arrow.Load InForm Metadata icon.
