Configure the web service location for a source data system
If you are using a clinical data capture system other than InForm, you must define its web service location so that Oracle DMW can send discrepancies to it and so that data reviewers can open the other system to view the discrepancy or data there.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
Select Development from the Lifecycle drop-down at the top of the page.
Tip:
In the Development lifecycle context you can configure File Watcher for any lifecycle stage.
Select the model and click Check Out.
Go to the System Configuration tab.
For each lifecycle stage, click the
Modify icon and enter:
System Lifecycle: Select the lifecycle stage in the external system that should exchange data and discrepancies with the selected DMW lifecycle stage.
Output Location: Select the name of the web service location for the external system, defined by your administrator.
Base URL: Enter the URL to use to view discrepancies and data in the external system from the DMW UI.
URL Listing Prefix: If required, enter a string to add to the beginning of the base URL to view data in the external system.
URL Listing Suffix: If required, enter a string to append to the end of the base URL to view data in the external system.
URL Discrepancy Prefix: If required, enter a string to add to the beginning of the base URL to view discrepancies in the external system.
URL Discrepancy Suffix: If required, enter a string to append to the end of the base URL to view discrepancies in the external system.
Click OK.
Back to Set up clinical data models
Parent topic: Create a file input clinical data model
