Copy tables
Copied tables include:
Columns, constraints, and blinding and data processing attribute values.
Validation checks that read from the selected tables, if all the source tables are included in the Copy operation.
Public custom listings that read from the selected tables, if all the source tables are included in the Copy operation.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models tab.
Select the model into which you want to copy tables and click Check Out.
In the Tables tab, click the
Copy Tables icon.
Select the source: either Study Data Model or Library Data Model.
To specify the tables to copy, start by selecting the study category, then the study (if you selected Study Data Model), then the model.
To help find any of these, type part or all of their name in the field above.
Click Clear Filters to remove all typed text and revert to the full list.
Click to select the table or tables to copy.
Specify how to handle any copied tables with the same name as existing tables in the model:
To replace tables with the same name that already exist in the current model, select Overwrite the same table names.
If you leave it deselected, the system leaves the existing tables as they are, copies the selected tables and adds
_1
(or an increment of 1) to the name of each copied table that has the same name as an existing table. Any validation checks and custom listings copied with the table are mapped to the copied table.
Click OK.
Back to Set up clinical data models
Parent topic: Add tables
