Create a codelist
Codelists specify a list of valid values that you can associate with a table column.
  1. Click the Navigation icon Icon shows a computer monitor. at the top of any page and then click Library.
  2. Select the Codelists tab.
  3. Select a project (or whatever study groupings are called in your company) in which to create the codelist.
    Tip:
    Selecting a grouping is required and can help users find the codelist. But codelists in any grouping can be used in any study.
  4. Click the Icon is a plus sign. Add or Icon shows a pencil. Modify icon. (If you are modifying the codelist, you must first check it out.)
    Tip:
    Modifying a codelist creates a new version of it. When you assign the codelist to a column, the column uses the current version. Columns that already use the old version will continue to do so unless you explicitly modify the column.
    • If you want to change all columns to the new version, modify the codelist.
    • If you want to be able to assign either version to a column, create a whole new codelist with the modified list of values.
  5. Codelist Name Enter a name.
  6. Description: (Optional) Enter a description such as its values to help users decide if this is the codelist they need.
  7. Click OK.
