Remove a codelist
Click the Navigation icon
at the top of any page and then click Library.
Select the Codelists tab.
Select a project (or whatever study categories are called in your company).
Select the codelist.
Click Check Out if it is not already checked out.
Click the
Remove icon.
You cannot remove a codelist if it is associated with a table column.
Parent topic: Create a codelist
