Create public custom listings
You can create standard public custom listings for data reviewers to use and modify.
Custom listings display only the columns you specify, making it much easier for reviewers to see the data they need. You also build a WHERE clause to filter the data displayed.
For details on creating a public custom listing, see this video:
If you have a visualization tool integrated with DMW, its users can see custom listings as well as data in the clinical data model they read from.
