Select packages
If you call functions in your code, you must select the package that contains the function in the Select Packages tab. If you use the Expression Builder, you do not need to use the Select Packages tab.
If you need to use a function and you plan to write the expression using the function in free text, open the Select Packages tab and select the packages you will use. This enables the system to generate the query code. The system displays all packages in the DMW_UTILS domain that meet certain criteria.
If you use the Expression Builder (reached by clicking the Modify Expression icon), you do not need to use the Select Packages tab.
Parent topic: Create public custom listings
