Explicitly mark as Not Used
  1. After you select a study, click the Study Configuration icon Shows gear with pencil iconfrom the navigation bar to open the Clinical Data Model tab.
  2. Click the Transformation tab to view the source and target tables.
  3. Select a single table or column.
  4. Select Mark as Not Used from the Mark drop-down in the table or column pane.
