Format checks on files being loaded
In any data load processing mode, the system checks incoming data against the format requirements of target columns, including data type, length, codelist values (if the column is associated with a codelist), and the nullable and check constraints.
When you configure File Watcher for a table, you define the Reported Errors parameter. During a data load, the system counts errors in the file until it reaches the number set in this parameter plus one. It then stops processing the file, reports the errors in the log file, and the data load fails. If the number of errors detected for each file in the text data load is not more than Reported Errors, then the data load completes with a Warning status.
Records that are rejected are captured and validated for other errors. All the errors found in each record are reported in a file called ComprehensiveErrRpt.csv.
The error file contains one row for each record with an error that says "ORIGINAL ERROR" in the Column Name column, another row for the original error, and additional rows for any other errors it finds on the same record. For the purposes of calculating the number of reported errors, the logic treats each record that can't be loaded as one error, even if it contains multiple errors.
Table 8-9 shows the error file entries for two records. Record 1 has two errors and Record 32 has one error. The string "CDR_W37_1D0156B9.TXT_TV486627301.Name" represents the full path of the erroring field, Name, for Record 1. The first part, "CDR_W37_1D0156B9," is the schema name and the second, "TXT_TV486627301," is the view based on the target table.
Table 8-9 Error file example
TABLE_NAME FILE_NAME REC_NUM COLUMN_NAME VALUE ERROR_MESSAGE
DEMOG
DEMOG.txt
1
ORIGINAL_ERROR
Captured in the TextLoad.log
ORA-20100: ORA-01400: cannot insert NULL into ("CDR_W37_1D0156B9.TXT_TV486627301.NAME")
DEMOG
DEMOG.txt
1
NAME
DEMOG
DEMOG.txt
1
HT
("CDR_W37_1D0156B9.TXT_TV486627301.HT")
DEMOG
DEMOG.txt
32
ORIGINAL_ERROR
ORA-20100: ORA-02290: check constraint
(("CDR_W37_1D0156B9.TXT_TV486627301
.AGE_CK) violated
DEMOG
DEMOG.txt
32
AGE
05
.AGE_CK) violated
