Merge a side transformation with the main transformation
When you merge the side model with the main model, any blinding and Not Used values are merged with the target model.
  1. Go to the main transformation for the target model.
  2. Check out the main transformation.
    Tip:
    If another user has the main transformation checked out, you cannot merge the side model into it. Either wait until you can check out the main transformation or ask the person who has checked it out to merge your side model.
  3. Select Copy from Side Model from the Actions drop-down list.
  4. Select the side model and click Next.
    If any tables have been modified since you created the side model, the system displays a message and you can choose to include the tables in the copy or not.
    • If you continue, the side model tables overwrite the main model tables.
    • If you cancel the copy operation, you can upgrade the side model to reflect changes made in the main model.
  5. Select the side model and click the Delete Side Model icon. You get a warning if it has not been merged with the main transformation.
