Modify an InForm input model
The InForm model must have exactly the same table structures as in InForm. You cannot make any structural changes.
Tip:
You can change attributes that apply only in DMW, but if metadata is reloaded from InForm either manually or automatically, your manual changes are lost. See Load InForm metadata for more information.
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models tab.
Select the model and the Development lifecycle.
In the InForm Configuration tab, click the Suspend Data Loading icon for the Development lifecycle.
Check out the model.
Make your changes. See:
Add or modify a table manually for information on adding tables aliases and SDTM identifiers. But do not add or remove tables.
Add columns to a table manually for information on adding column aliases, codelists, and SDTM identifiers. But do not add or remove columns.
Install the model. The system uses the old version until the new one is installed. The model must have a status of Installable.
A model is not installable if it does not have any tables or if any of its tables are not installable. A table is not installable if it has no columns.
Back to Set up clinical data models
Parent topic: Modify a clinical data model
