Validation checks
This window shows any validation checks that have already been created for the selected validation check batch. To make any changes, check out the batch.
To create a new validation check, click the
Add icon. See Create a validation check.
To copy a validation check from another study, select Copy Checks from the Checks drop-down list. See Copy a validation check.
To modify an existing validation check, select it and click the
Modify icon. For an explanation of the fields, see Create a validation check or Complete a validation check using a custom program.
To delete a validation check, select it and click the
Delete icon.
Parent topic: Create validation checks
