Create a validation check batch
Validation checks are executed in batches. Before you create a validation check you must create a batch for it. Use batches to group validation checks in logical ways:
Checks that have dependencies on each other so they must be executed in a particular order.
Standard checks kept together for reuse in many studies.
Checks on the same clinical data model that should all be triggered by the same event or scheduled for the same frequency.
Next: Create a validation check.
Parent topic: Create validation checks
