Why does it say Upgrade Required?
If there have been metadata changes in the source clinical data model—for example, change of column length—that affect any validation check in a batch, the system sets the value of the Upgradable column to Required. Select the batch, then select Upgrade Batch from the Actions drop-down, then install the batch.
Parent topic: FAQs
