Why isn't the transformation triggering my validation check batch job?
Set this up in two places:
- In the transformation that writes to the clinical data model that the validation check reads from, set Can Trigger to Yes in Add or Remove Source Models.
- In the validation check batch, select Can Be Triggered.
Parent topic: FAQs
