View existing data marts and their run history
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models tab.
Select the model.
Click the Data Extraction tab.
Select a data mart. Its run history appears in the lower pane.
In the Run History pane, click the link in the relevant column to:
View the output.
Download the output.
View the log file.
Back to Set up clinical data models
Parent topic: Extract data from a clinical data model
