View run history
Transformations are displayed by the name of their target clinical data model.
To view table transformations, click a transformation's node.
To view run history and pending jobs, select a transformation in the upper pane.
To view log files, click the icon in the column for the type of job:
Log: The most recent manually submitted job.
Triggered Job Log: The most recent triggered job.
Install Job Log: The most recent installation of the transformation.
Parent topic: Run transformations and view history
