What happens if there's a protocol change?
When metadata changes in InForm, DMW detects it:
  • During data loading.
  • When you promote a model to a higher validation status.
  • When you save changes to a remote location or study account.
The load, promotion, or save is not allowed and a message appears that you need to reload metadata.
You can also run the Compare Metadata report by clicking its icon in the InForm configuration tab, and then import metadata.
