What happens when I mark tables and columns as Not Used?
  • Any mappings to the table or column are deleted.
  • The transformation's status can be Complete without mapping the table or column. Completeness is required for validation and installation.
    Columns populated by TMS are never included in calculating completeness even if they are marked Used.
  • Validation checks and custom listings that are dependent on a table or column marked Not Used are disabled. If you later mark the table or column as Used, you must manually reenable the validation checks and custom listings.
  • The table or column is not visible in the Listings pages.
