Check Out a Clinical Data Model
Use this API to check out a study or library clinical data model.
Name
DME_PUB_DF_DATA_MODEL.CheckoutDataModel
Signature
procedure CheckoutDataModel(
p_api_version IN NUMBER
p_init_msg_list 	IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit 	IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level	 IN NUMBER default 	CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
pio_naming	 IN OUT NOCOPY  cdr_naming_version_obj_type,
pi_comment 	IN VARCHAR2,
x_return_status	 OUT NOCOPY  VARCHAR2,
x_msg_count	 OUT NOCOPY  NUMBER,
x_msg_data	 OUT NOCOPY  VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model you are checking out.
  • PI_COMMENT Enter a checkout comment.
