Check In a Clinical Data Model
Use this API to check in a study or library clinical data model.
Name
DME_PUB_DF_DATA_MODEL.CheckinDataModel
Signature
procedure CheckinDataModel(
p_api_version IN NUMBER,
p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE
p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL
pio_naming IN OUT NOCOPY cdr_naming_version_obj_type
pi_comment IN  VARCHAR2
x_return_status OUT NOCOPY  VARCHAR2
x_msg_count	OUT NOCOPY  NUMBER
x_msg_data OUT NOCOPY  VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model you are checking in.
  • PI_COMMENT Enter a checkin comment.
