Check In a Load Set Definition
Use this API to check in a Load Set definition.
Name
CDR_PUB_DF_LOADSET.CheckInLoadSetDefinition
Signature
PROCEDURE CHECKINLOADSETDEFINITION(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_BASEOBJECT  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_COMMENT  IN    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_BASEOBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Load Set definition that you want to check in.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
  • PI_COMMENT (Optional) Enter the reason for checking in the Load Set.
