Undo Check Out for a Load Set Definition
Use this API to undo a check out for a Load Set Definition.
Name
CDR_PUB_DF_LOADSET.UndoCheckOutLoadSet
Signature
PROCEDURE UNDOCHECKOUTLOADSET(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT  NOCOPY  VARCHAR2,
  x_MSG_COUNT OUT NOCOPY NUMBER,
  X_MSG_DATA  OUT  NOCOPY  VARCHAR2,
  PIO_BASEOBJECT  IN OUT  NOCOPY  CDR_BASE_OBJ_TYPE,
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • P_COMMIT (Optional) Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not commit upon completion. Enter FND_API.G_TRUE to override the default behavior.
  • P_VALIDATION_LEVEL (Optional) Accept the default value to perform full validation. No other values are currently supported.
  • PIO_BASEOBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE that contains object attributes. Enter values to identify the Load Set definition that you want to undo check out.
    The required attributes are: COMPANY_ID, OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER.
