Create a Binary Output
Use this API to create a binary output object.
Name
CDR_PUB_EXE_EXTERNAL.CreateBinaryOutput
Signature
PROCEDURE CREATEBINARYOUTPUT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_NCOMPANYID  IN    NUMBER,
  PI_VFILENAME  IN    VARCHAR2,
  PI_VDATA  IN    RAW := NULL
Parameters
This API has standard parameters (see "Standard Parameters") and the following parameters:
  • PI_NCOMPANYID (Mandatory) Enter Company Id.
  • PI_VFILENAME (Mandatory) Enter the File Name.
  • PI_VDATA (Optional) Enter the RAW input to stream up the output.
