Upload an Output BLOB
Use this API to upload an output BLOB generated by an external processing engine into Oracle LSH.
Name
CDR_PUB_EXE_EXTERNAL.UploadBlobOutput
Signature
PROCEDURE UPLOADBLOBOUTPUT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_NJOBID  IN    VARCHAR2,
  PI_VFILENAME  IN    VARCHAR2,
  PI_NPRREFID  IN    VARCHAR2,
  PIO_BLOBSTREAM  IN OUT    BLOB
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NJOBID (Mandatory) Enter the JOB_ID of the job that generated the output.
  • PI_VFILENAME (Mandatory) Enter the filename associated with the Planned Output.
  • PI_NPRREFID (Mandatory) Enter the PRREF_ID of the Oracle LSH executable. This attribute is available from the cdr_jobs_v view.
  • PIO_BLOBSTREAM (Mandatory) This is a parameter of type BLOB. Enter BLOB to be uploaded.
