Upload an Output CLOB
Use this API to upload an output CLOB into Oracle LSH.
Name
CDR_PUB_EXE_EXTERNAL.UploadClobOutput
Signature
PROCEDURE UPLOADCLOBOUTPUT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_NJOBID  IN    VARCHAR2,
  PI_VFILENAME  IN    VARCHAR2,
  PI_NPRREFID  IN    VARCHAR2,
  PIO_CLOBSTREAM  IN OUT    CLOB
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NJOBID (Mandatory) Enter the JOB_ID of the job that generated the output.
  • PI_VFILENAME (Mandatory) Enter the filename associated with the Planned Output.
  • PI_NPRREFID (Mandatory) Enter the PRREFID of the Oracle LSH executable. This attribute is available from the CDR_JOBS table.
  • PIO_CLOBSTREAM (Mandatory) Enter the variable name for the CLOB in the database.
