Enable or Disable Validation Checks
Use this API to enable or disable Validation Checks.
Name
DME_PUB_VALIDATION_CHECK.EnableDisableValidationChecks
Signature
PROCEDURE ENABLEDISABLEVALIDATIONCHECKS
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_VC_MAP_COLL IN CDR_BASE_OBJ_COLL,  PI_ENABLE_FLAG IN VARCHAR2,
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_VC_MAP_COLL (Mandatory). This is a parameter of collection type CDR_BASE_OBJ_COLL that contains CDR base object attributes. The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER for Validation Checks maps.
  • PI_ENABLE_FLAG (Mandatory). Enter '$YESNO$YES' for enabling and '$YESNO$NO' for disabling.
