Reorder Validation Checks
Use this API to re-order validation checks.
Name
DME_PUB_VALIDATION_CHECK.ReorderValidationChecks
Signature
PROCEDURE REORDERVALIDATIONCHECKS
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_VC_MAP_COLL IN OUT NOCOPY DME_XFORM_MAP_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_VC_MAP_COLL (Mandatory). This is a parameter of collection type DME_XFORM_MAP_COLL which is a table of DME_XFORM_MAP_OBJ_TYPE type. The attributes required for this API from DME_XFORM_MAP_OBJ_TYPE are:
    • COMPANY_ID
    • OBJ_ID
    • OBJ_VER
    • EXECUTION_ORDER_NUMBER
