Get an Output's BLOB
Use this API to retrieve the BLOB associated with an output object.
Name
CDR_PUB_PRINT_OUTPUT.GetOutPutBlob
Signature
FUNCTION GETOUTPUTBLOB(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  PI_NCOMPANYID  IN    CDR_NAMINGS.COMPANY_ID%TYPE,
  PI_NOUTPUTID  IN    CDR_NAMINGS.OBJ_ID%TYPE,
  PI_NOUTPUTOBJVER  IN    CDR_NAMING_VERSIONS.OBJ_VER%TYPE
) RETURN BLOB;
Return
Type BLOB
Description BLOB
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NCOMPANYID (Mandatory) Enter your company ID.
    To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
  • PI_NOUTPUTID (Mandatory) Enter the obj_ID of the output whose BLOB you want to retrieve.
  • PI_NOUTPUTOBJVER (Mandatory) Enter the obj_ver of the output whose BLOB you want to retrieve.
