Submit a Print Request
Use this API to print a specified output. The API submits a request to the Oracle LSH printing concurrent program that prints the specified output.
Name
CDR_PUB_PRINT_OUTPUT.SubmitPrintRequest
Signature
FUNCTION SUBMITPRINTREQUEST(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_NCOMPANYID  IN    CDR_NAMINGS.COMPANY_ID%TYPE,
  PI_NOUTPUTID  IN    CDR_NAMINGS.OBJ_ID%TYPE,
  PI_NOUTPUTOBJVER  IN    CDR_NAMING_VERSIONS.OBJ_VER%TYPE,
  PI_VPRINTERNAME  IN    FND_PRINTER.PRINTER_NAME%TYPE := NULL,
  PI_VCOVERSHEET  IN    VARCHAR2 := NULL
) RETURN NUMBER;
Return
Type NUMBER
Description Concurrent Request Id
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NCOMPANYID (Mandatory) Enter your company ID.
    To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
  • PI_NOUTPUTID (Mandatory) Enter the obj_id of the output you want to print.
  • PI_NOUTPUTOBJVER (Mandatory) Enter the obj_ver of the output you want to print.
  • PI_VPRINTERNAME (Mandatory) Enter the printer name.
  • PI_VCOVERSHEET (Mandatory) Enter the text for the coversheet. You can enter text only up to 4000 bytes.
