Remove a Hierarchy Column
Use this API to remove Business Area Hierarchy Columns.
You cannot remove a Column that is currently part of a Join. If you remove a Column, and if the next Column's Group By Previous setting is Yes, then that setting is changed to No.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.RemoveHierColumns
Signature
PROCEDURE REMOVEHIERCOLUMNS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_BUS_HIERCOLUMNS_COLL  IN OUT    CDR_BUSAREA_HIER_COLS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_BUS_HIERCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_HIER_COLS_OBJ_TYPEs. For each Column that you want to remove, initialize a CDR_BUSAREA_HIER_COLS_OBJ_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,HIER_OBJ_ID,HIER_OBJ_VER,TD_COMPANY_ID,TD_OBJ_ID,TD_COL_COMPANY_ID,TD_COL_OBJ_ID,POSITION,GROUP_WITH_PREVIOUS_RC.
