Reorder a Hierarchy Column
Use this API to reorder the Columns of a Business Area Hierarchy.
The API enforces validation rules for Column sequence.
Name
CDR_PUB_DF_BUSINESSAREA_HIER.ReorderHierCols
Signature
PROCEDURE REORDERHIERCOLS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_BUS_HIERCOLUMNS_COLL  IN OUT    CDR_BUSAREA_HIER_COLS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_BUS_HIERCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_HIER_COLS_OBJ_TYPEs. For each Column, initialize a CDR_BUSAREA_HIER_COLS_OBJ_TYPE, providing the new value for POSITION NUMBER relative to the other Columns, and then extend the collection. You must initialize all existing Columns.
The following attributes are required: COMPANY_ID,HIER_OBJ_ID,HIER_OBJ_VER,TD_COMPANY_ID,TD_OBJ_ID,TD_COL_COMPANY_ID,TD_COL_OBJ_ID,POSITION,GROUP_WITH_PREVIOUS_RC.
