Compare flags, tags, and categories
The following table compares flags, tags, and categories. All are available for use in any study.
Table 1-2 Flags, Tags, and Categories
Object | Applied To | Applied By | Used as Filter? | Has Multiple States? | Used for |
Flag |
Records |
User or validation check. InForm flag assignments are imported and can be viewed but not changed. |
Yes |
Yes |
Data management |
Tag |
Discrepancies |
User or validation check, via actions |
Yes |
No, but can be used to create discrepancy substates |
Discrepancy management |
Category |
Discrepancies, Validation Checks, Flags |
Validation check or user |
Yes |
No |
Discrepancy and data management |
Parent topic: Cross-study setup
