Set up coding in TMS
Prerequisites:
  • TMS must be installed.
  • TMS must be integrated with DMW as specified in the DMW Installation Guide.
  • Dictionaries and TMS domains must be defined in TMS. Domains allow you to customize terminologies differently for different studies by creating domain-specific terms and classifications. Domains also determine default TMS system behavior.
    Tip:
    DMW displays the domain description, if there is one, for the user to select a TMS domain for use with a particular study. If there is no description, the system displays the TMS domain name.
For more details on TMS coding, see this video:
