Add a Column to a Table in a Clinical Data Model
Use this API to add a column to a table in a clinical data model.
Name
DME_PUB_DF_DATA_MODEL.AddColumnToDataModelTab
Signature
procedure AddColumnToDataModelTab( p_api_version IN NUMBER p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL x_return_status OUT NOCOPY VARCHAR2 x_msg_count OUT NOCOPY NUMBER x_msg_data OUT NOCOPY VARCHAR2 pio_naming IN OUT NOCOPY cdr_naming_version_obj_type pio_variable IN OUT NOCOPY cdr_var_obj_type pio_column IN OUT NOCOPY cdr_dm_column_obj_type );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_NAMING This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter
values for the column and its namespace, the table. Six attributes are required:
- COMPANY_ID Company ID of the Table.
- OBJECT_TYPE_RC Enter
$OBJTYPES$COLUMN
. - NAME Name of the column.
- NAMESPACE_OBJ_ID Object ID of the Table.
- NAMESPACE_OBJ_VER Object Version of the Table.
- DESCRIPTION Description of the column.
- PIO_VARIABLE (Mandatory): This is a parameter of type CDR_VAR_OBJ_TYPE.
Column objects are based on variable objects. Enter values as follows:
- COMPANY_ID To get your company ID, use CDR_PUB_DEF_FACTORY_UTILS.GetCompanyId.
- ORACLE_NAME: Enter an Oracle name for the column.
- ORACLE_DATATYPE_RC: Specify the data type. Enter one:
'$ORADATATYPES$VARCHAR2'
,'$ORADATATYPES$DATE'
, or'$ORADATATYPES$NUMBER'
- LENGTH:
For Date data type columns, no length is required.
For VARCHAR2 data type columns, the value must be between 1 and 4000.
For Number data type columns, the maximum value is 38.
- PRECISION: If the column is of data type Number, enter the precision.
- SAS_V6_NAME: Enter a name that conforms to SAS V6 requirements, if needed.
- SAS_V8_NAME: Enter a name that conforms to SAS V8 requirements, if needed.
- SAS_LABEL: Enter a SAS label, up to 200 characters.
- SAS_FORMAT: Enter a SAS format or leave blank to default to the value you entered for LENGTH preceded by a dollar sign ($).
- NULLABLE_FLAG_RC: If null values are allowed in the
column, enter
'$YESNO$YES'
. If not (the column is mandatory) enter'$YESNO$NO'
. - DEFAULT_VALUE: Enter NULL or, if the column should always have a particular data value, enter the value.
- PIO_COLUMN: This is a parameter of type CDR_DM_COLUMN_OBJ_TYPE. Some
attributes are the same as for the variable parameter PIO_VARIABLE. The following
attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER, POSITION, SAS_LABEL,
NULLABLE_FLAG_RC. Enter the same values you did for the variable. In addition:
- OBJ_ID and OBJ_VER: Enter NULL.
- POSITION: Enter the column's position in the table relative to other columns.
- REQUIRED_FLAG_RC: Enter the opposite value that you entered for Nullable in the Variable parameter.
- NULLABLE_FLAG_RC: Enter the same value that you entered for Nullable in the Variable parameter.
- CODE_LIST_COMPANY_ID: To associate the column with a codelist, enter the company ID of the codelist. To find this and related values, query public view DME_PUB_CODELIST_V.
- CODE_LIST_OBJ_ID: To associate the column the column with a codelist, enter the object ID of the codelist.
- CODE_LIST_OBJ_VER: To associate the column the column with a codelist, enter the object version of the codelist.
- IDENTIFIER_VAR_COMP_ID: If you are assigning an SDTM ID to the column, enter the company ID of SDTM identifier. To find this and related values, query public view DME_SDTM_COL_IDENTIFIERS_V.
- IDENTIFIER_VAR_OBJ_ID: If you are assigning an SDTM ID to the column, enter the object ID of SDTM identifier.
- IDENTIFIER_VAR_OBJ_VER: If you are assigning an SDTM ID to the column, enter the object version of SDTM identifier.
- USABLE_FLAG_RC: Enter
'$YESNO$YES'
or'$YESNO$NO'
. This value is not used by the system. - MAPPABLE_FLAG_RC: Enter
'$YESNO$YES'
if the column can be mapped to a source column in a transformation. Internal columns such as CDR$DUP_NUM and CDR$SKEY should have the value'$YESNO$NO'
.If set to
'$YESNO$NO'
, the system ignores the column when calculating mapping completeness and when automapping. - MASKING_VALUE: If the column belongs to a table with column-level blinding and should be blinded, enter the masking value.
- MASKING_CRITERIA: If the column data values should be masked only in some rows, enter the masking criteria as a SQL expression.
- SOURCE_KEY_FLAG_RC: Enter null.
- ALIASES: Enter one or more alternate names for the column in a comma-separated list with no spaces, for use in automapping transformations.
- INFORM_REF_PATH_NAME: Leave blank.
- MASKING_LEVEL_RC: Specify the masking level for the
column: ,
'$MASKING_LEVEL$NONE'
,'$MASKING_LEVEL$COLUMN'
, or'$MASKING_LEVEL$CELL'.
- MASK_VALUE_EXPR_ID: To use a predefined expression to generate masking values, enter the expression's object ID.
- MASK_VALUE_EXPRESSION: If Masking Value is '$MASKING_LEVEL$NONE' then pass NULL values. For others pass expression details to parameter DME_XFORM_EXPR_OBJ_TYPE type; see Add a Table to a Clinical Data Model parameter BLINDING_CRITERIA_EXPRESSION.
- MASK_CRITERIA_EXPR_ID: To use a predefined expression to determine which cells to mask, enter the expression's object ID.
- MASK_CRITERIA_EXPRESSION: If Masking value is '$MASKING_LEVEL$COLUMN' or '$MASKING_LEVEL$NONE' then pass the NULL values. For '$MASKING_LEVEL$CELL' pass criteria expression details to parameter DME_XFORM_EXPR_OBJ_TYPE type; see Add a Table to a Clinical Data Model parameter BLINDING_CRITERIA_EXPRESSION.
Parent topic: Create and Modify Clinical Data Models
