Create and Modify Clinical Data Models
This is a public interface for clinical data model-related operations, including creating, modifying, and removing models, and checking models in and out. It also includes APIs for adding, modifying, and removing tables and constraints to tables within models.
You can also create tables with columns and constraints within a model by uploading metadata files. See the Oracle Health Sciences Data Management Workbench User's Guide for more information.This section contains the following topics:
- Create a Study Clinical Data Model
- Create a Study Clinical Data Model from a Library Model
- Modify a Model's Name and Description
- Check Out a Clinical Data Model
- Check In a Clinical Data Model
- Undo a Clinical Data Model Checkout
- Install a Study Clinical Data Model
- Promote a Clinical Data Model to Quality Control or Production
- Remove a Clinical Data Model
- Upgrade a Clinical Data Model to the Latest Library Model Version
- Copy the Subject and/or Subject/Visit Table
- Add a Table to a Clinical Data Model
- Modify Table in Clinical Data Model
- Remove Table from Clinical Data Model
- Add a Column to a Table in a Clinical Data Model
- Modify Column Display Characteristics in a Clinical Data Model Table
- Modify a Column in a Clinical Data Model Table
- Remove Column from Clinical Data Model Table
- Add a Constraint to a Clinical Data Model Table
- Modify a Constraint in a Clinical Data Model Table
- Remove Constraint from a Clinical Data Model Table
- Reorder Columns in a Clinical Data Model Table
- Display Metadata Differences between Tables
Parent topic: Clinical Data Models
