Upgrade a Clinical Data Model to the Latest Library Model Version
Use this API to upgrade a study clinical data model that was created from a library model to the latest version of the library model.
Name
DME_PUB_DF_DATA_MODEL.UpgradeSDMToLatestLDM
Signature
PROCEDURE UpgradeSDMToLatestLDM(p_api_version IN NUMBER p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_commit in varchar2 default cdr_pub_def_constants.g_false p_validation_level in number default cdr_pub_def_constants.g_valid_level_full pio_StudyModObj IN OUT NOCOPY cdr_naming_version_obj_type x_return_status OUT NOCOPY VARCHAR2 x_msg_count OUT NOCOPY NUMBER x_msg_data OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_STDYMODOBJ (Mandatory): This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model that you are upgrading.
Parent topic: Create and Modify Clinical Data Models
