Create a Study Clinical Data Model from a Library Model
Use this API to create a study clinical data model in a study domain from a clinical data model in a library. The complete model is copied, including all tables, columns, and constraints. The system maintains a relationship between the library model and the study model. If the library model is modified, you can upgrade the study model to the new version—see Upgrade a Clinical Data Model to the Latest Library Model Version. However, any local changes you have made to the study model are lost.
Name
DME_PUB_DF_DATA_MODEL.CreateStudyDMFromLibDM
Signature
PROCEDURE CreateStudyDMFromLibDM
(P_API_VERSION
IN NUMBER,
P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
PI_LIBMODOBJ IN NOCOPY CDR_NAMING_VERSION_OBJ_TYPE,
PI_STDYMODOBJ IN NOCOPY CDR_NAMING_VERSION_OBJ_TYPE,
PIO_DMOBJ IN CDR_DATA_MODEL_OBJ_TYPE,
X_RETURN_STATUS OUT NOCOPY VARCHAR2,
X_MSG_COUNT OUT NOCOPY NUMBER,
X_MSG_DATA OUT NOCOPY VARCHAR2,
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_LIBMODOBJ (Mandatory). This is a parameter of type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the following attributes for the
library model and its namespace, which is the library domain for the therapeutic
area or other category. Use CDR_PUB_DEF_FACTORY_SUPPORT.GetNamingObject to get
the naming version attributes.
- COMPANY_ID To get your company ID, use CDR_PUB_DEF_FACTORY_UTILS.GetCompanyId.
- NAME Enter a name for the library clinical data model.
- NAMESPACE_OBJ_ID Enter the object ID of the parent library domain.
- NAMESPACE_OBJ_VER Enter the object version of the library domain.
- NAMESPACE_START_OBJ_VER Enter
1
- NAMESPACE_END_OBJ_VER Enter
999999
- DESCRIPTION Enter a description for the library clinical data model.
- OBJECT_TYPE_RC Enter
'$OBJTYPES$DATAMODEL'
- PI_STDYMODOBJ (Mandatory). This is a parameter of type
new study model and its namespace, which is the study domain.
- NAME Enter a name for the study clinical data model.
- NAMESPACE_OBJ_ID Enter the object ID of the parent study domain.
- NAMESPACE_OBJ_VER Enter the object version of the study domain.
1
999999
- DESCRIPTION Enter a description for the study clinical data model.
- PIO_DMOBJ (Mandatory). This is a parameter of type CDR_DATA_MODEL_OBJ_TYPE.
Enter values for the following attributes for the new study clinical data
model:
- DM_NAME Enter null.
- DM_NAMESPACE_OBJ_ID Enter the object ID of the parent study domain.
- DM_DESCRIPTION Enter null.
- DM_TABLE_COLL Leave empty. To add tables use Add a Table to a Clinical Data Model.
- LIBRARY_FLAG_RC Enter
$YESNO$NO
because this is a study model, not a library model. - MODEL_TYPE_RC
- To create a target model, enter
$MODELTYPE$TARGET
. - To create an input model, enter
$MODELTYPE$INPUT
- MODEL_SUBTYPE_RC
- If the model type is
$MODELTYPE$TARGET
, then model subtype is null. - If the model type is
$MODELTYPE$INPUT
, then model subtype can be either$INPUTMODTYPE$INFORM
or$INPUTMODTYPE$FILE
- CREATE_BA_FLAG_RC Enter
$YESNO$YES
to create a Business Area to enable visualizations of data in the model or$YESNO$NO
. - BA_SCHEMA_NAME By default, the schema uses the model name. If you want a different schema name, enter it. It must be unique across the DMW instance.
Parent topic: Create and Modify Clinical Data Models
