Check In a Work Area
Use this API to check in a Work Area and all the object instances it contains.
Name
CDR_PUB_DF_WORKAREA.CheckInWorkArea
Signature
PROCEDURE CHECKINWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASENAMING IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_BASENAMING (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area that you want to check in.
The following attributes are required: COMPANY_ID,OBJECT_ID,OBJECT_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
- PI_COMMENT (Optional) Enter the reason you are checking in the Work Area.
Parent topic: Define and Modify Work Areas
