Modify a Work Area
Use this API to modify the name and/or description of an existing Work Area. (Use CDR_PUB_DF_WORKAREA.UPDATEUSAGEINTENT to modify a Work Area's Usage Intent attribute.)
Name
CDR_PUB_DF_WORKAREA.ModifyWorkArea
Signature
PROCEDURE MODIFYWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to modify and the values you want to change. All attributes are required.
- PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. Enter values to identify the Work Area that you want to modify and enter new values for the attributes you want to modify.
Parent topic: Define and Modify Work Areas
