7 Advanced: Run jobs and check history
- View and edit your subscriptions to job status notifications
- Run transformations and view run history
- Run validation check batches and view run history
- Generate the Discrepancy Differences Report
You can generate the Discrepancy Differences report from the Discrepancies interface to view any variances between discrepancies in Oracle DMW and the source system. - Reprocess discrepancies that failed to be sent to InForm
- Check if data files loaded
- FAQs
